you also sometimes see 4R7 which is 4.7ohms or 4k7 which is 4.7k
Quote from: Psi on July 05, 2012, 08:29:14 amyou also sometimes see 4R7 which is 4.7ohms or 4k7 which is 4.7kEasier to say too. "Four Kay Seven" vs "Four Point Seven Kay"Dave.
It is also a lot easier to read on a schematic for us folk with older eyes 1R2 is obvious but if you replace a 1.2 Ohm with a 12 Ohm because you didn't see the microscopic decimal you have problems debugging your circuit.
Quote from: caroper on July 05, 2012, 11:23:13 amIt is also a lot easier to read on a schematic for us folk with older eyes 1R2 is obvious but if you replace a 1.2 Ohm with a 12 Ohm because you didn't see the microscopic decimal you have problems debugging your circuit.I have older eyes,but I've never had that problem!
I think the decimal point thing has more to do with the quality of reproduction using photocopying and faxing of schematics, back in the days when PDF wasn't yet around.
The rectangles for resistors were to save draughtsmen work.Now we can use wiggly lines like I was brought up on!
Quote from: vk6zgo on July 05, 2012, 03:22:20 pmThe rectangles for resistors were to save draughtsmen work.Now we can use wiggly lines like I was brought up on!Not everyone uses that silly symbol for a resistor, over here we use the rectangle.
Im looking at a CONTINUITY TESTER Circuit, and it says it needs 10k, 30k, and 1k resistors. Does that mean 10,000, 30,000, and, 1,000 ohm's?
