Color codes workaround: multimeter.
Or buy SMT chips, which you can't see anyway (maybe), or are completely unmarked.
Color codes in other things are, I'm sure, a standard difficulty. Some programs allow you to reconfigure the colors. Some don't. Lots of cheap and poor software (such as you might use for laying out hobby PCBs?*) might not support such options, and you're left staring at a red-green blob that's not much help...
*Disclaimer: I haven't used any of the cheaper/free tools in anywhere near enough depth to know if this is the case.
Lesson to others who might be curious:
- Red-green ambiguity is the most common colorblindness, affecting something like 5-10% of men (I think?). For being so common, it's still not well appreciated.
- Blue is safer, but the other kinds of colorblindness (which do affect blue and other combinations) still aren't terribly rare or anything.
- For sure, avoid red/green as a distinctive feature. Lights, graphics, messages, displays, whatever. Use intensity to make things stand out. If possible, use different appearances, styles or textures to emphasize things further.
- Accessibility is also very practical. The more readable something is, the better it will be from a distance as well, or under poor lighting conditions. If you're ever doing something industrial, keep this in mind for safety!
(Ed: I think I wrote the first lines before F_E did, but I didn't finish the rest of these lines until, well..
