That's like asking if you could use salt instead of sugar.
Either learn how do these components work or stop guessing and pulling random component types and asking if they could be interchanged.
NTC can be replaced only by NTC.
PTC can be replaced only by PTC.
MOV can be replaced only by MOV.
NTC is a resistor with negative temperature coefficient, used for temperature measurements or inrush current limiting (high resistance when cold, warms up at current flow an decreases resistance).
PTC has a positive tempco, used mainly for temperature measurements or special types of PTCs also can be used as resettable fuses (PPTC, polyfuse, polyswitch)...
MOV (or "varistor") is a resistor with voltage dependence. The higher the voltage, the less the resistance. Used only for surge/spike voltage protection. At normal conditions and operating voltage, almost no or negligible current flows. If the voltage is higher than the rating, it will decrease its resistance several orders of magnitude and shorts the surge.
