Author Topic: Is it possible to use a continuity tester here?  (Read 7536 times)
Offline BondguyTopic starter
« on: March 23, 2017, 08:43:00 pm »
Is it possible to use a continuity( short  circuit) tester to test  a microchip such as ATMEL IC for a  short circuit?
Or is there any danger that by using continuity( short  circuit) tester I can destroy the microchip if that had been working well?
( the tester uses a voltage and I am not sure that voltage can not destroy any transistor (or a similar ) inside )
My idea is to compare GND pin with other pins and if the chip is shorted , there will an indication of a beep.
Is it workable or not?
The following users thanked this post: ali6x944
Offline not1xor1
Re: Is it possible to use a continuity tester here?
« Reply #1 on: March 24, 2017, 06:58:33 am »
you can't trust your multimeter continuity function for that purpose
the circuit below might work as it will beep when the resistance is very low (even few milliohms if you set the trimmer for that) and the test current is less than 200µA
the resistors with (*) are 1% and the buzzer I used is just a transducer so the second opamp works as a square wave oscillator.
PTC and diodes are input protection (in case of charged capacitor or live circuit test)
the led won't turn on when the battery is low
« Last Edit: March 24, 2017, 07:01:38 am by not1xor1 »
Offline Gyro
« Reply #2 on: March 24, 2017, 09:30:20 am »
I've long been intrigued by the 'Ultimate continuity tester' published in Electronic Design. It can even distinguish shorts from inductors, transformer windings and reverse connected windings....
http://electronicdesign.com/analog/ultimate-continuity-tester-hides-many-tricks-its-sleeve
Best Regards, Chris
Offline james_s
« Reply #3 on: March 24, 2017, 09:10:45 pm »
That's pretty clever.
I've occasionally used my ESR meter to check for shorted semiconductors. The high frequency makes inductors appear as much higher impedance, the voltage is too low to forward bias semiconductors. Capacitors will of course fool it and look like a short if it's a good low-ESR capacitor but even so a short will usually appear lower impedance than even a good capacitor.
Offline freda
« Reply #4 on: November 23, 2021, 12:19:52 am »
The circuit figures in the article are blank now (for me)  :(
Online ledtester
« Reply #5 on: November 23, 2021, 10:53:06 am »
Found it!
There is a caveat that the circuit might not work as expected.
http://kripton2035.free.fr/Continuity%20Meters/ed-ultimateconti.html
(also saved to web.archive.org)
Update: Also archived here: https://www.eevblog.com/forum/oshw/continuity-tester-with-glitch-capture/msg2250480/#msg2250480
See also this forum post:
http://www.8052mcu.com/forumchat/read/190943
1330277-0
1330283-1
« Last Edit: November 23, 2021, 11:40:42 am by ledtester »
The following users thanked this post: Gyro, Diyaudio_enthusiast
Offline Gyro
« Reply #6 on: November 23, 2021, 10:02:36 pm »
This is the one I really trust to work though...
https://www.eevblog.com/forum/projects/continuity-tester-circuit/msg2652777/#msg2652777
Best Regards, Chris
