so my question involves a common problem i am having in finding the right multimeter i need.
the fluke 115, for example, would probably be the perfect multimeter i could get but the amps range is not low enough. it only goes to mamps and no uamps, which is suggested in my books and some projects.
with this in mind, do you, in ur suggestion, still get it even though it lacks the range or do you keep on going?
just curious. thanks
