I put 1k resistor between - and GND and take only 40mV rms, current below 0.05mA that's the minimum the meter can measure. Same between + and GND.
I do same tests with my home made power supply with initially I take 16Vac rms, but putting a load make the voltage drop to an insignificant value.
Thanks guys for your help.
Cheers,
Pinipon
