Can an opto-coupler be used to provide isolation in feedback circuits...
eg. say in my case, where the input voltage of 0 to 200V D.C is from the armature of a dc motor, is passed through low pass filter and a voltage divider, and the final output is 0 to 5V D.C, but i did not provide any kind of isolation... what can we use to provide isolation. can we use a opto-coupler, but the output voltage after isolation should vary linearly from 0 to 5V as the input varies from 0 to 5V.
Or is buffer-opamp a good choice... What can I use to provide isolation...
I searched on the internet and found some DC/DC isolators like "recom r1s 0505", but the problem with that is, the output is a constant 5V, and is useless for feedback applications....
