Most MOSFETs are designed for switching, not linear operation, and can only handle a small fraction of their rated power if kept in their linear region. Also if you reduce the heater voltage by 50% you'd be dissipating as much power in the MOSFET as in the heating element, but the heat from the MOSFET is not likely to be in a useful place.
Especially if you are using a MCU with a PWM module, it is therefore far easier to simply PWM it, via a gate driver chip if you need fast control to get a more stable temperature. Simple, slow bang-bang (on/off) control can be done with a MCU and a logic compatible (low gate threshold) MOSFET without a gate driver, but this will result in some temperature cycling which you may not want.
