I was just thinking that if the physical earth under your feet was an active part of the electrical distribution network, it could make for some 'interesting' experiences.
There is a legendary tale in telephone circles related to that. In early days, and especially in rural areas, telephone lines were sometimes ground-return, but almost all of them were "selective ring" party-lines. Many of the "selective ring" schemes used a local ground reference for the ring voltage which approaches 100VAC at different frequencies (ring frequency being one of the selective-ring schemes).
Anyway, there was a customer complaint from a rural customer that there was a strange problem with their telephone ringer. Apparently when a call came in, the phone never rang for several cycles until their dog barked, and then the phone rang.
They sent a repairman out and he climbed a pole and clipped on his butt-set and dialed the customer's number. Sure enough several ring cycles and nothing happened. Then their old dog got up and barked a couple times and peed on the metal rod he was chained to. And then the phone rang.
Apparently the dog was chained to the telephone ground rod which had gradually increased impedance and no longer had enough conductance to the earth. So when the ring current came down the line, it shocked the dog through his chain, he got up and barked in complaint, and then peed on the ground rod, temporarily lowering the impedance enough to pass sufficient ring current. Maybe old telco lore, but maybe true.
FYI: Butt-set:
