While thermistors are rated up to ~150°C, they are only stable, long term, up to 100°C, above that, use should be only intermittent. Platinum RTDs, particularly the thin film types are accurate and can be found for under $5 and they do require an amplifier stage. Thermocouples are relatively cheap but require a compensation junction plus amplifier to work as their microvolt output signals are much too low to work with otherwise. Unless you require very accurate measurement, the RTD interface amplifier can be relatively simple to implement and an RTD has a much higher change per degree than a thermocouple.
