Author Topic: Is There Anyone Who Knows Which Multimeter Can Test the Reballed Maiboard?  (Read 14922 times)
Offline DevianTopic starter
Hello, I am in electronic PCBA repair, now i want a Multimeter which can test reballed main boards, who can tell me which is the most suitable one: can meet my need but not that expensive.
Offline joelby
What exactly do you want to test?
Normally to check BGA soldering, you would use an x-ray machine, not a multimeter.
I reball Xbox 360 mainboard, for example, the GPU,after reballed it, I need to test the electronic effect, that is why i look for a multimeter,any one with recomendations?
Offline joelby
Can you describe what you mean by "electronic effect"?
Honestly, pretty much any multimeter will be equally suitable for this task.
Offline IanB
If you tried to replace a GPU on an Xbox 360 with that apparent skill set, then you broke it. No need to test it, it's broken.
Offline DaveW
    • WattCircuit
Do you mean reflowed; ie. got a hot air gun and heated up the GPU? In which case, testing with a multimeter is pointless, just reassemble it and try it. If it doesn't work, try it again but heating it for a bit longer.
There aren't methods for detecting a BGA connection that is high impedance without using high end optical inspection, TDR or x-ray, and none of these are possible at a typical hobbyist level.
Re: Is There Anyone Who Knows Which Multimeter Can Test the Reballed Maiboard?
« Reply #6 on: November 01, 2011, 09:57:57 am »
Thank you guys, who can tell me how can I know the Xbox 360 GPU is well reballed?
« Reply #7 on: November 01, 2011, 10:00:46 am »
There is any way to prove my reballed gpu work well? If does not work, it means my GPU already broke? And no ways to make up except only to buy a new one?
Offline Bored@Work
« Reply #8 on: November 01, 2011, 10:18:19 am »
Get it X-rayed. And get a clue.
Offline Neilm
« Reply #9 on: November 01, 2011, 07:07:01 pm »
If you mean you want to test for shorts using continuity testing, remember the output voltage of the multimeter might be enough to damage the newly soldered GPU. For instance, to meet some of the wiring standards in the UK, they have to output at least 4V.
Yours
Neil
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline IanB
« Reply #10 on: November 01, 2011, 07:19:09 pm »
That sounds like a disaster. For electronics use I think I want my continuity and ohms measurements to use 0.5 V or less to reduce the risk of damage to other components during in-circuit tests. I really would not want my DMM outputting large voltages like that with the possible exception of the diode test function.
Offline codeboy2k
« Reply #11 on: November 01, 2011, 08:21:34 pm »
The continuity tester of the DMM should definitely be well below 0.5V and I'd even prefer to see it below 0.2V. This is to ensure against forward biasing any PN junctions in circuit.
Offline EEVblog
« Reply #12 on: November 01, 2011, 09:59:18 pm »
No, there isn't a way to test it.
Apart from switching it on and testing it after you solder it. It'll either work or it won't. If it doesn't work, you won't know if that's because it's a bad chip, or bad soldering, or both.
Dave.
Offline Neilm
« Reply #13 on: November 01, 2011, 10:03:34 pm »
Exactly my point - I don't know what most DMMs do but if you get one that does output 4V or more (BS7671 gives 4-24V) you will blow things up. I think I will measure what my ones at work give.
Neil
alm
  • Guest
« Reply #14 on: November 01, 2011, 10:12:41 pm »
Open circuit or for very high resistances, most meters produce a voltage of 5V or so. For lower resistances some meters are specified to be below 0.2V.
I don't really understand the 4V requirement, is this about puncturing oxides? How about just requiring people to use a megger if insulation voltage matters? Otherwise this should be a clear distinction between electronics (below diode drop) and electricians (>4V) meters. Probably a separate mode, like the Fluke Lo Ohms feature.
Offline hacklordsniper
  • Country: hr
  • Don't turn it on, take it apart!
    • HackLordSniper
« Reply #15 on: November 02, 2011, 06:22:28 am »
Just try it,  i have seen people heat those motherboards in mothers stoves just after she baked cookies and it worked. It would be good possibly to limit the power supply current from burning something if there is a short, possibly powering only the motherboard from lab power supply and see what happens
Oh, the joy of sending various electronics to silicon heaven
Offline Neilm
« Reply #16 on: November 02, 2011, 07:32:19 pm »
BS7671 is the standard for building wiring in the UK so that is where the 4V is specified. Some meters pick that as a requirement.
I measured a couple of multi-meters at work - one of them is reasonably cheap and you had to select the range. In the top range (>200k) the output voltage was 5V until you had about 5k on in. More than enough to fry a chip or two.
Neil
alm
  • Guest
« Reply #17 on: November 02, 2011, 07:48:58 pm »
Why this 4V minimum? What trouble are they trying to solve?
Offline Neilm
« Reply #18 on: November 02, 2011, 08:39:20 pm »
I think it is due to other requirements in BS7671 - for instance limits on the resistances. The instruments have to output 200mA into a short circuit so you will probably find that there is a 20 ohm max resistance limit somewhere in the document.
Neil
alm
  • Guest
« Reply #19 on: November 02, 2011, 08:55:53 pm »
The minimum short circuit current doesn't make sense to me either, but I'm not familiar with the standard, so I digress. 4V 200mA sounds just fine for some diodes like ESD protection diodes. Better keep those meters far away from any electronics.
« Reply #20 on: November 03, 2011, 03:24:45 am »
Dave.
Hi. your opinion really help me much, but if there is an easy way to test the ship before reballed or before soldering? How to test a X360 gpu reballed chip to make sure it is working before soldering ? Many thanks
« Reply #21 on: November 03, 2011, 03:29:39 am »
Yes I have the same question in my mind.
Offline joelby
« Reply #22 on: November 03, 2011, 03:41:19 am »
It is basically impossible to test the chip without soldering it onto the board and seeing what happens when you turn it on.
Maybe you could do it if you had chip-specific testing rig with a BGA socket, but only the manufacturer would have something like that, and only they would know how to accurately test it. With a multimeter you could compare the impedance between every ball and every other ball (if you could guarantee that your test didn't destroy the chip), and see if this is different to another chip from the same batch, but on a large chip this represents hundreds of thousands of individual tests and you won't have any way to know if a difference is meaningful or not.
Have you considered taking it to an XBox repair place?
« Reply #23 on: November 05, 2011, 06:30:25 am »
Neil
Thank you, if so, is there anyway to check the gpu before solering? I just want to know why it does not working after I soldering it? it is me that damaged it during the solering process because of wrong operation ? or the GPU was already damadged when arrived to me?  Thanks,guys
« Reply #24 on: November 05, 2011, 06:31:28 am »
Yes I have the same question with you.
