well does it look like a diode to a multimeter ?
I'm very new to SMD stuff but usually that stripe at 1 end is the cathode
Tantalum capacitors exhibit diode like behaviour, which can be used to determine the anode from cathode. When connected backwards, a tantalum capacitor will conduct like a diode, dropping a small voltage. When connected correctly, the capacitor will charge, then block the voltage when fully charged. The same is true for other polarised capacitors. The aluminium capacitor was developed from the electrolytic rectifier.
Now in this case, if it's dropping about 600mV, when forward biased, then it's most likely a silicon diode. If you're unsure, you could try it on a capacitance tester: it should read below 100pF. If it were a tantalum capacitor, then the capacitance would be much higher >100nF.
