Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
is this a typical high and low side switching circuit?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: is this a typical high and low side switching circuit? (Read 1273 times)
superwester
Contributor
Country:
on:
February 18, 2018, 04:10:11 am »
i was struggling thinking that i needed to control two high side switches.
but on a second though, as the circuit is powered by a bipolar supply its a good old high and low side half H bridge.
am i right?
circuit:
https://imgur.com/gallery/pmp1I
sorry if this requires more info from my part, but im assuming it does not.
Logged
superwester
Contributor
Country:
Re: is this a typical high and low side switching circuit?
Reply #1 on:
February 18, 2018, 04:13:06 am »
i made the same question a while back and, stupidly enough, i didnt post any circuit and i cant erase it
Logged
Jwillis
Super Contributor
Country:
Reply #2 on:
February 18, 2018, 04:49:30 am »
That looks single phase.2 diodes in that configuration is a full wave rectifier.The Fets are switches.
Logged
superwester
Contributor
Country:
Reply #3 on:
February 18, 2018, 03:15:59 pm »
im aware of that part, but i dont know if i can consider both fets on the high side of the load or the one controling the positive rail is on the high side and the other controlling the - rail is the low side switch. im guessing its the later
Logged
PartialDischarge
Super Contributor
Country:
Reply #4 on:
February 18, 2018, 03:32:47 pm »
For your purpose you can consider it an H bridge.
For a moment when I saw the two capacitors in series, this circuit reminded me of an NPC converter.(neutral point clamped)
Logged
superwester
Mechatrommer
Super Contributor
Country:
reassessing directives...
Reply #5 on:
February 18, 2018, 05:51:23 pm »
the diodes and caps are
delon bridge voltage doubler
but in this case is to produce dual dc rails. the mosfets (bjts?) are the switching circuit. when top is turned on, it provides current to the windings, after sometime, it will be turned off, and the bottom mosfet will turned on to draw current from the windings. since the bottom mosfet is on the lower rail, so it should be the low side pass element.
Logged
superwester
superwester
Contributor
Country:
Reply #6 on:
February 18, 2018, 06:39:27 pm »
thanks, all clear now.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
