You need three adjustments in total: one to vary the sense/divider ratio, to null CMRR; one to null the DC offset voltage (due to op-amp error and unbalanced leakage currents); and one to adjust overall gain (to calibrate slope).
Do your DC sweep thingy in a Monte Carlo simulation, where the resistors all have some specified tolerance. You'll see the problem.
Since you have two sets of divider resistors, the CMRR ratio adjustment can be placed in any of them, as long as the adjustable range is give or take the resistor tolerance. You might make one side intentionally "long", then make the other adjustable between normal, long, and twice as long (so, for 1% resistors, make the one side longer by 1%, and give the other an adjustable range of 0-2% longer).
