I've worked on this broken PSU before, and this time I pulled the main transformer. The windings all read OL or 0.05 ohm on the 2ndary (I just created that). The 2 primaries are only 0.10 and 0.20ohm. I'm reading about 0.03 ohm with my Brymen869 shorted. So this is nothing like bigger transformers I've checked where the it's like +2ohm pri, +50 across sec. This is a step down trans, and pretty small, but IDK.
Using a 120VAC to 12VAC wall transformer, I'm feeding that into the pri side of the SMPS Trans , and I did a short circuit test and it drew 1.6A-ACrms , I also just used a 1k resistor into the prim, and put it on the scope across the resistor and I'm getting 40Vpp
I get nothing off the other side, looks the same on the scope without power.
How would I even know that the pri. is not fried and just acting a pure wire. The windings have me confused more than they should.
I'm avoiding the conclusion here, but am I missing something or is is dead...which means taking it apart and another big roadblock
pictures of the smaller low quality 1, but about the same
http://www.realhardtechx.com/index_archivos/Page17610.htmthe 120V to 12AC (I'm so used to AC-DC wall packs...) is 230 ohm : 2.5 ohm, and it's a bit smaller than the SMPS trans
