hi JackOfVA
Reading your post I got to thinking of what the cost could be of
Dumping 50KW into an open cable or shorted cable.
Not a real good thing to do I am sure.
With this three relay setup and a minor goof you could have Transmitter to antenna and also output of power amp. Would probably be bad for something.
C
In a Broadcast Transmitter setup,the main damage would be to the switch----the Transmitter would "grunt" & turn itself off.
High Power Transmitters are pretty forgiving,for the following reason:
Much of the complexity of a commercially made Broadcast or Communications Transmitter is jn the protective circuits.
This has been pointed out by JackOfVA .
It was always interesting to be on transmitter duty during a lightning storm - you would see the flash and hear the thunderclap and the transmitter relays would click for a fraction of a second and that was it. It was rare to have to do a manual reset - the automatic overload circuit would detect the fault, shut down the transmitter and then restart after the protection circuit determined that the fault had cleared.
We also had a coax short while I was on duty. This was a 9 tower directional array station, 50 KW transmitter output and the towers had a "dog house" with some impedance matching (far from 50 ohms, just enough to make 50 ohm coax feed feasible), and then a long run of either 1.625 inch or 3.25" copper air line coax cable (depending on the power to the particular radiating element) back to the transmitter building and the main antenna phasing/matching network. For some reason we never determined, one of the 1.625" diameter coax cables failed at one of the insulating disks - when we dug up the cable there was a nice trail of melted copper bridging the center and outer conductors. However, the change in impedance from 9 normal phased antennas to 8 phased antennas and one short was not enough to trip the transmitter out permanently. In fact, all I saw at the time was a quick trip/reset but after the reset the common point current was wrong - not a lot wrong, but enough to indicate all was not normal. It took a TDR to locate the short, and then a back hoe to excavate the coax - buried 6 ft or so deep. All in all, I think it was about 3 days from fault to repair, during which time we operated under temporary "parameters at variance" authority from the FCC.
Another interesting fault we had involved cable migration. The night transmitter was an old RCA plate modulated job (the 50 KW was an RCA "Ampliphase" transmitter which combined two phase modulated identical transmitter sections to yield AM. Incredibly complicated exciter but it had low frequency response better than any plate modulated transmitter and was more efficient.)
The 10KW transmitter had a suitably hefty 3-phase power transformer with secondary voltage around 5 or 6 KV. The mercury vapor rectifiers were in the transmitter bay and the power transformer was about 15 or 20 feet distant, and the raw AC was run via coax cable through a conduit between the transformer room and the rectifier bay. I can't recall the coax type, but it was larger than RG-8 diameter, but smaller than RG-17. Probably close to 0.75 inch jacket diameter. The 10KW transmitter had been in place for 15 or 20 years at the time. One night, the afternoon engineer went to flip the transmitter control from standby to operate and the transformer room filled with smoke and the primary side breakers tripped. One of the secondary winding coax cables developed a center conductor to shield short. The chief engineer had the failed coax X-rayed and you could see where the center conductor had migrated at a bend to the point where it was nearly touching the shield and was close enough to arc over. A foot or so either side of the bend was perfectly centered. The center conductor probably moved 0.01 inch a year for 20 years.
In any event, working as a transmitter engineer at the AM station was a great job at the time - I worked nearly a full time job there and also full time in school as there was plenty of idle time to do homework while babysitting the transmitter.
First photo shows the control console at the transmitter building. At the left foreground is part of the 50 KW ampliphase transmitter. Further along that wall is the old RCA 10KW high level modulated transmitter.
Second photo is rather unevenly exposed, but the phaser control panel is at the right, along with monitoring equipment. At the end of the room is the "last ditch" backup transmitter, a 1KW Gates.
These photos are 40 years old and have major color shifts.
