Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Isolation transformer.. Math!
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Isolation transformer.. Math! (Read 3145 times)
edmundopt
Regular Contributor
Country:
There's theory and practice...
on:
February 21, 2014, 04:31:56 pm »
Hello,
I have some work to do with a 320W Switching power supply, it is a 240VAC(max) mains input.
I want an isolation transformer to work with it, so I need a new one, I am looking at this :
https://pt.rs-online.com/web/p/transformadores-de-seguridad/4369808/
Wich is BLOCK TIM 500 rated at 230AC with 500VA, two output of 2x115VAC, wich I will join to make 230VAC
Will it be near the limit ? Maybe a 800VA one will be better?
This will be a one time only job, so, saving € is important!
What is the math on isolation transformers for power output ?
Logged
Fsck
Super Contributor
Country:
sleep deprived
Re: Isolation transformer.. Math!
Reply #1 on:
February 21, 2014, 04:36:00 pm »
Are you fully loading that PSU? And, do you have the specs of the PSU?
Logged
"This is a one line proof...if we start sufficiently far to the left."
edmundopt
Regular Contributor
Country:
Reply #2 on:
February 21, 2014, 04:59:46 pm »
MeanWell SP-320-24, 24volts output, stepper motor driver up to 8Amps, and resistive dummy load up to 10amps.
Logged
CaptnYellowShirt
Frequent Contributor
Country:
Scooty Puff Jr.
Reply #3 on:
February 21, 2014, 06:18:20 pm »
If its any kind of modern PSU, its power factor should be really close to 1.00 (~0.95). In that case it should be drawing something very close to 320VA. 500VA should be just fine:
320 / 0.95 / 0.92 = 366 VA
power / PF / trans eff = peak VA from wall
Last Edit: February 21, 2014, 06:22:08 pm by CaptnYellowShirt
Logged
edmundopt
Regular Contributor
Country:
Reply #4 on:
February 21, 2014, 06:22:27 pm »
Aren't there any pratical maths for transformers?
for example, relays can switch :
75% on resistive loads
40% on inductive loads
20% on motor
10% on Incandescent bulbs
Logged
Zero999
Super Contributor
Country:
0999
Reply #5 on:
February 21, 2014, 08:10:39 pm »
Does the switched mode power supply have power factor correction? If so a 500VA unit will do, otherwise it may need to be larger, depending on the actual current drawn.
How long do you intend to operate it for? If it's just for test purposes, it may be fine for a short period of time, say under 10 minutes.
Logged
edmundopt
Regular Contributor
Country:
Reply #6 on:
February 21, 2014, 08:46:59 pm »
yes, it has active power factor correction. About Meanwell, they do pretty good PS, this one is 87% or better, 0.95PF.
All of their PS beat the specifications mentioned.
Testing, periods of 1 to 2 min, 5max.
Logged
Zero999
Super Contributor
Country:
0999
Reply #7 on:
February 21, 2014, 09:08:35 pm »
Then I think a 500VA transformer is ample.
Logged
Fsck
Super Contributor
Country:
sleep deprived
Reply #8 on:
February 23, 2014, 02:38:50 am »
Quote from: Hero999 on February 21, 2014, 09:08:35 pm
I get: (320W / .82 psu efficiency [they spec 87%])/(0.90 PF [their specs are >0.95 for "typical"]) / (0.90 transformer efficiency [again, assuming you may have a slight dud]) = 464VA.
Meanwell's specs are incomplete, efficiency and PF appear to be specced at 230VAC and 25C ambient. I think you'll probably be fine unless one or both item don't meet their basic specs.
Logged
megajocke
Regular Contributor
Country:
Reply #9 on:
February 26, 2014, 09:40:41 pm »
The transformer is probably rated for output power so its efficency shouldn't matter.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
