keep in mind methanol is pretty toxic and has negative effects on your body apart from short term toxicity while ethanol is very metabolizeable (but hydroscopic) and isopropyl is so-so in terms of toxicity (it will be converted partially to acetone in your body, which occurs naturally, but if you drink it you will get pretty wasted pretty quickly and you will have horrible diabetes breath). When you inhale the vapors it happens but to a much lesser extent. Methanol is downright bad compared to ISO and Ethanol. If you need something that dries very fast use diethyl ether over methanol IMO, since its vapors will metabolize to ethanol and be partially excreted unchanged, but the vapors will intoxicate you very quickly and its a massive explosion danger due to its density... still safer with good work practices then methanol IMO, since explosion hazard beats cancer surgery 15 years later any day, since its easier to protect yourself from that with safe work practices then fumes, spills and broken PPE.
For me its much better psychologically to know a threat is completely gone rather then to have some nagging persistent thought of DNA mutation ETC that can randomly pop up.
