I've used denatured Ethanol and Isopropanol (IPA). 95% denatured Ethanol is great for getting the crud off really dirty boards - wave soldered or reflowed with no defluxing then used in a poorly ventilated room by chain-smokers till a crust of gooey cigarette tar has built up on every surface.
However, before using denatured Ethanol on anything sensitive, its advisable to evaporate about a ml to dryness on a watchglass (or similar concave glass surface) using warm air or other gentle heat source, and note if there is any objectionable residue*. Also observe the last of the liquid closely as it evaporates to see if it is oily. On sensitive high impedance circuits its only the first stage of a cleaning process and needs to be followed by an aqueous phase to remove ionic contamination and then by a good technical grade of 95% (or purer) IPA to quickly remove the residual water from the aqueous cleaning phase + any detergent residue. The board can then be dried with no risk of iron component leads and other parts rusting, or heat damage due to prolonged and excessive drying temperatures.
On less sensitive circuits, you can probably skip the aqueous cleaning phase unless a water soluble flux was used, or objectionable streaking was left after drying. Blotting off as much denatured Ethanol as possible followed by an IPA rinse (without drying in between) is usually adequate.
As IPA forms an azeotrope with water, (87.7% IPA by weight), and absorbs moisture from the air, if you ever need to use it for rapid water removal, you need drier IPA than that, so that traces of moisture aren't left behind as it evaporates. Keep all bulk IPA containers tightly stoppered, and only dispense enough for a few days use.
* If you are intending to use denatured Ethanol as a single cleaning stage, you will probably want to test the conductivity of the residue if there was any apparent. Add a drop of deionised water and see if the residue is water soluble then compare conductivity with a control drop of the deionised water, taking care to use clean electrodes and immerse them the same distance with the same separation.
