Hi everyone New here and looking for help
So I've had a JOVY isolder 40 for years now. And I love it. It does everything I ask it to. The problem is the handle tends to melt itself from the heat of the tip. It makes it difficult after time to get the tips in and out. I've had to fix it and drill the end out a few times. I've also broken the handle a few times and had to glue it back together. Now it's at the point where the tips aren't making good contact inside the handle and it's not working very well. Always losing connection with the tip.
Does anyone have any leads on where to buy just a new handle? I would buy another new unit, but a friend of mine bought 3 in a row and all got the handle so hot you couldn't even hold onto it. Apparently I lucked out and got a good one. Just the very end is melting on mine.
I do repairs on large car amplifiers. So I need something I can change a delicate IC as well as remove large 1/0ga terminal blocks. The JOVY fit the bill perfect with it's sensing technology it would get just the right temp for small stuff, but was a beast on large joints too without even changing the tip or any settings what so ever. It is a great machine in my opinion.
I did order a Edsyn 951SXe to try. And with it's 95W rating I was optimistic, but it severely let me down. Even my partners 60W Weller out performed it.
I did a test with all 3 irons on the same joint for 30 seconds to test heat loss at the tip. The edsyn and Weller we're on 800*. The jovy is auto sensing. No adjustments. It's tip started out at 375* out of the base.
Weller - 415*F and falling
Edsyn - 350*F and falling (temp probe actually got stuck in the cold solder at that point)
JOVY - 475*F and steady
As I said I would really like to just fix this JOVY, but would take recommendations on a new iron as well if it can match the jovy. (Under $300)
