So tonight's mission was successful.
The input amp worked (mono). Gain looked good. Response, for as far as I could tell was grand on sine and "fair" on square. I have waveform caps I can share later. I tested at 1Khz, 20Khz and for some fun all the way up to 1.2Mhz. Things go ropey above about 600Khz, but it wasn't that bad.
Square wave at 20Khz has quite a slow rise/fall time and a little overshoot, but I don't think it's that big an issue.
It was also successful in that the two RD Tech power supplies did a grand job of providing +12 0 -12V rails.
Also successful in revealing just how important decoupling caps on the power rails is. I had huge noise ripples all over the place without them.
Also successful in confirming the cheap chinese kit build waveform generator is crap. After decoupling the noise off the rails, I was depressed at the noise on the output until I hit "HOLD" a few times on the wave and confirmed 100% the noise was on the input and not being added by the amp. Little oscillation pulses at a much higher frequency flowing long the waveform. They existed on both input wave and output wave, so I ignored them. (Signal gen was running on a completely separate battery, so clean power, though it did share the ground from the PSUs).
Finally, "successful" in finding out my laptop power supply has no damn discharge what-you-ma-call-ems on the main caps. Bastard thing zapped me after I unplugged it and it hurt. I do make an effort not to touch the pins when I pull a plug as I have been bitten before, but it got me. Grrr. Nothing like a little 120/240V zap to piss you off. It has a proper UK plug with part insulation, so there is no way to touch the pins while they are connected to the mains, so it was definately the caps on the mains side discharging into my finger
