So a little update on progress. Things are coming together. Or... rather they aren't yet. They things are starting to exist.
Linking in a few cross threads on sub projects:
Headphone (power) amp - created as a standalone.
https://www.eevblog.com/forum/beginners/circuit-review/msg1471160/#msg1471160Ideas and prototypes for meters.
https://www.eevblog.com/forum/beginners/audio-bar-graph-small!/msg1465125/#msg1465125
The DAC:
https://www.eevblog.com/forum/beginners/audio-dac-output-low-pass-filter/msg1450490/#msg1450490So right now the DAC and headphone amp are in service and working fine, with caveats.
I added gain to the DAC (swapping 12K input resistors for 3.9K) and while it doesn't upset my gear it upsets my brothers amp which clips horribly. <shrug> I gained to to see if it would run headphones, it did, but weakly. However it drives as a preamp absolutely fine, it drove my existing headphone amp to where I no longer needed full volume for loud listening. In the full circuit I will put the gain back to what it was as it has a premp stage after it.
Issues: The L and R output are swapped, doh!
The headphone amp. As it's standalone I couldn't build it for my internal chosen levels, so I gave it a whack of gain, 7.666 actually. Powered it from a voltage divider rail split with two caps. It performs excellently. I "can" get it to full throttle with my headphones, but I can't tolerate it for very long. Face melting. I've used it all weekend and on a dial that goes from 1-10, 3 is comfortably loud, 4 is kicking loud, 11 is only tolerable for a short period. But, this achieves my goal, I don't need to run my volume controls to MAX all the time it's back in my control. The downside of high gain is it amplifies noise, so even touching the bare metal pot make audible noise... and angers the voltage divider noise below.
Issues: The voltage divider virtual ground is highly sensitive to power rail noise. Also the input biasing to that virtual ground is sensitive to cap matching. When I was using 220uF input caps to minimise low end roll off, they were unmatched by about 20% and the right hand channel ended up biased about 2V lower than the feedback reference, so... no output. 22uF are easier for the 22K bias resistors to pull, but I'm tempted to lower them and increase the cap size again. If I lower the 22k bias resistors (biasing the amp side to the virtual ground) it will form an RC filter with the cap and I might put them back up to 220uF. Alternatively, I could buy higher tolerance caps.
The voltage divider noise, in the short term with the board I have, I might lower the 4k7's to 2k2's or even 1ks to make it a bit more powerful to avoid uA range pick up. Burning a few mA is worth it.
I'm thinking of making a revision two of the amp with these improvements and ... maybe a opamp virtual ground buffer and a chain of power rail filtering caps.
What I'm learning is that when you don't build things to a price, but to a spec they sound better.... or maybe that's just confirmation bias and pride.
Still on the list:
Prototype the bluetooth module. Probably breaking it out with mod wire on a perf board. It needs a differential to single ended amp stage and it would be nice to combine that with the preamp, but I doubt I have the experience to do that... or it might not work.
Prototype a few bar graphs for the meter module.
Start trying to layout a full board with everything on it.
Start thinking about how I house this thing. I'm already thinking it's going to end up in a case that's 4" or 5" sqaure with the meter board off the back, angled up, console style.
