Author Topic: Just to check with you guys, what capacitor is this?  (Read 2644 times)
Offline SmallWalrusTopic starter
« on: February 03, 2012, 04:17:11 am »
Sorry for the newbie question, I figured that I probably am wrong, so I thought to post a picture of it :)
This is a 22pF capacitor right? However what does the g81 underneath it mean? And how do I find out the voltage for it?
Offline metalphreak
  • http://d.av.id.au
    • D.av.id.AU
Re: Just to check with you guys, what capacitor is this?
« Reply #1 on: February 03, 2012, 06:44:40 am »
That looks like a tantalum capacitor (since it has a polarity marking) and is most likely 22uF. Could also be one of those fancy SMD package electrolytic ones?
g81 will be some kind of manufacturer code. Could be anything from a date/week code to tolerance specs to a batch number. Hard to tell without knowing which brand/model it is to look at the datasheet.
22picofarads would normally be much smaller, like the size of those tiny brown/beige ceramic caps.
« Reply #2 on: February 03, 2012, 02:36:28 pm »
Thanks for your reply :)
How do I find out what voltage it is though?
« Reply #3 on: February 03, 2012, 02:43:50 pm »
Is there some guide on how to read these codes too? I've found 2 on Google and from what they said, it does seem like "220" is a 22pF value (as much as it might not make sense).
Offline mariush
« Reply #4 on: February 03, 2012, 02:53:12 pm »
220 simply means  22 x 100   = 22 ... uF , pF ... up to the size of the capacitor... at that size it's more likely to be 22uF, it's too large to be pF.
821 would mean  82 x 101 = 820uF etc etc
as for the voltage... since they're near a chipset or some chip/controller etc... the voltages are probably around 0.8-1.8v so they're probably rated for 2-2.5v ... can't be sure without actually probing or without checking chips around the area (see maybe there's a switching voltage regulator and maybe you can determine the voltage based on its datasheet and surrounding parts)
« Last Edit: February 03, 2012, 02:56:53 pm by mariush »
Offline Martin_bg1
  • Country: bg
    • GPStronic
« Reply #5 on: February 03, 2012, 04:24:57 pm »
It is not possible to be pF cause it has polarity.
About the voltage, if its possible turn it on and measure it .
