Hello,
For a while now I have been using a Y splitter to power my two monitors. Last week my secondary monitor made a very strange sound and the backlight turned off. It also smelled like fried electronics. I pulled the monitor out of my setup and set it up on the floor with it's own power cable and ran it for most of the day with a test pattern displayed on it and it worked fine.
Today, I put the monitor back on my desk and connected it with the Y splitter as I had been before and the backlight would light for a second then go out. This was repeatable every time I powered on the monitor. However I'm now using it to type this post with it plugged in via a standard kettle lead. I find this odd since I'm having no trouble with my main monitor which it powered by the other half of the Y splitter.
I'm in the UK so using 240v mains at 50Hz. I Don't believe there's anything major wrong with the monitor since it's running through a 5A fuse in the plug and an RCD (GFI) protecting the whole house.
Has anyone experienced this or have an idea what might cause this?
