I buy the MiniBoards from ExpressPCB and I am limited to board size. There is a real need to use smaller packages.
I stayed away from SMD for a while but now they are the only parts I order. If there is no other choice, I will use Thru-Hole but I prefer to avoid them.
Soldering SMD ICs is dead simple: Tack a couple of corners and drag solder the rest. If there are solder bridges, remove them with SolderWick. Small packages like 0805 and smaller are best soldered in a reflow oven - a converted toaster oven.
I really don't want to have to hold smaller components in place with tweezers while I solder each end. It's much easier to just place them all in solder paste and cook the board.
Before I built the reflow oven, I used a GE Hotplate. This is perfect for the MiniBoards. Set the board on top, turn the hotplate on high, wait until the solder flows and remove the board (without shaking all the parts off). Really, it doesn't get any easier than this. I have one board with something north of 80 0805 packages and I certainly didn't solder them by hand!
BTW, I'm an old man with dubious eyesight and the only visual aid I use is an OptiVisor 10. I would like a microscope but I can't justify it.
ETA: This is STRICTLY a hobby. I have never worked as an Electronics Technician or Electronics Engineer. It's just for fun so I can't rush out and buy everything I want. Fixed income and all that...
