Being rather new to electronics and having just bought my first oscilloscope (an HP 1743A), I’ve been trying to measure the things I have on hand with it. One of my recent forays was an ATX PC power supply. So I hooked things up and was rather surprised to see quite a bit (+/- 750mV) of ripple on the 5V output when looking at it with a TPD of 20 uS, even without any load. Reading that PC power supplies often need some minimum level of draw (mine said 1.5A @ 5V) to regulate voltage correctly, I wired up some resistors to create a ~2A flow. The ripple got much worse and I got a high-frequency whine from the supply. So I popped a 4700 uF capacitor in and that silenced the whine and reduced the ripple – but even then I’m still left with nearly 1.5V PP of ripple. It doesn’t look like HF noise from my setup – it’s a nice, solid, steady waveform but just one that dances between 4.x and 5.5V. The ATX spec says the ripple on 5V should be 60mV or less, so either a) the power supply is bad, b) my equipment is bad, c) my technique is bad, or d) all is fine and this what I should expect. Any thoughts on which it might be?
