I'm making a custom enclosure by laser cutting "layers" of the enclosure which are held together by vertical rods at the corners. I've done a few of these already and I always end up wasting a load of material on the middle layers because they are just essentially outlines with the middle cut out. Doing it this way however is still cheaper than 3D printing (costs me about 20 quid per enclosure) and I end up with a clear acrylic enclosure, which is hard to get otherwise. The reason I'm posting is because the 6 layers I need to cut have an internal free area of 40mm x 88mm, so if anyone has any "shapes" in 3mm clear acrylic they could use, let me know and I can add them inside the cutout of the middle layers.
