To all and sundry ... this is a general help call. What I'm after is the Lattice ispDesignExpert (and ispDesign) software. This stuff is "supposedly" available from Lattice but as you can see from the following case that I've raised with them - they no longer have it.
The reason for chasing this software is that I need to target some really early devices that ispLever just doesn't support.
If anyone has it, can you *please* get in contact with me.
Here is the case details from Lattice, so have a read and a giggle.
---> CUT HERE <---
Dear **********,
Your support case #C140646-081915 regarding "ispDesignExpert software download" has been updated.
The new notes are updated below:
____________________________________________________________________________
Hi Brendon,
We tried checking the availability of the ispDesign Expert software at our factory and unfortunately we were not able to locate any other version of the software that can help you currently.
I regret for the inconvenience this has caused you.
We are working on adding a list of software which are no longer supported and not available with Lattice, so future customer do not face similar problem and may get the information initially. Thank you for your suggestion on this point. Lattice provides PCN when the devices are getting Obsolete but, will also start working on upgrading website with old software information.
---> END CUT <---
