Hi everyone, first of all thanks for a great community. I love all the information being inserted into my brain everytime i visit this site!
I have a question i hope i can get some help with.
I am making a raspberry pi project, where the powersource is going to be 4x Nimh 1.2V 2400mAh batteries in series. Giving a total of 1.2V 9600mAh to play with.
My plan is to feed this power to a DC-DC boost converter like this one, which takes inputs from 0.8V and boosts it to 5V
http://www.ebay.com/itm/DC-DC-Step-Up-Boost-Module-Voltage-Conversion-Input-0-8V-to-3-3-3-3-6-4-5-6V-/332182189317?var=&hash=item4d5799f505:m:mbRHQya7_cObL187KktlmDQThen this 5V will be fed to the Raspberry pi.
I just wanted to also make a LBO (Low battery indicator), for protecting the batteries.
My plan was to make a red LED light up, when batt voltage would hit 1V.
I have looked at different schematics of how to make one, and found this one:
I found it to be a very simple sketch, but then my problem was i couldnt find a 1V zener diode. Since they apperently dont get made.
So i was looking into maybe using a TLV431, but it has a voltage reference of 1.24V, or 2.5V other model. And it seems to be a bit more complicated than my first shown sketch.
So i have made a blokdiagram of what my plan for the PSU + LBO would look like, and i was hoping you could help me decide what LBO circuit is the most simple to build for this project.
The LBO does not need to cut off power when low voltage is detected, it should just power ON an LED. That is most suitable for my project.
I was hoping an alternative, where resistors and other simple components could be used, instead of using an IC.
Attatched is my blokdiagram.
I hope i have been succesfull in pulling my question out of my head and writing it down on the world wide web, so another human being can understand it
Thank you very much and have a wonderful day
