what is the most common faults with LCD monitor power supplies?
I have a Prolite E1908WS.
When I turn it on it flashes the image makes a small noise then goes out again but the signal light stays on.
I took it apart
and powered the lamps with an inverter from a scanner and it worked, so it is not the lamps that is funny.
the capacitors are also OK
