I hadn't come across that! Thanks for the tip. Really encouraging though you still use that when you have a de5000. Is it far off from the at328 meters in absolute terms?
It depends on the capacitor and the settings used on DE-5000. For example if I use the test capacitor that came with the component tester, the component test reports 225.8 nF while the DE-5000 reports 226.8 nF. That is close enough for me. However electrolytic capacitors are a different story; if I measure a random electrolytic capacitor from my stash the component tester reports 125.9 uF, but the DE-5000 reports 113.84 uF (@ 1 kHz). This is quite a difference. Now if I use my Fluke multimeter it reports 131 uF, and my cheap Voltcraft VC850 reports 128.6 uF for the same capacitor. So which one is right (if any)?
One thing to keep in mind is the capacitance of a capacitor is not as straightforward as it seems. If two different meters report different values that doesn't mean that one is wrong and the other one is right (or both are wrong); it could even be that both are right(!). That is because the capacitance of a capacitor is not a fixed value independent of the conditions (such as voltage, frequency..etc). That is why datasheets (should) report the testing conditions/methodology. It also is the reason why on the DE-5000 you can specify the measurement frequency. For example if I set the measurement frequency on the DE-5000 to 100 Hz the electrolytic capacitor I mentioned above measures 121.7 uF, when I set the frequency to 10 kHz is measures 101.7 uF, when I set the frequency to 100 kHz it doesn't even recognize it as capacitor. It gets even worse when measuring the ESR of a capacitor.
The main reason I tend to use the component tester more often than the DE-5000 is convenience; just insert the component press the button and the result is "close enough" for most uses. It is also a lot smaller than the DE-5000 so it tends to be within arms reach on my (small) bench. The DE-5000 is more versatile tool to determine the characteristics of capacitors and inductors since you can specify among others the measurement conditions (which is necessary if you need to compare against a datasheet), but that makes it also harder to use and more likely to confuse you. Another advantage of the DE-5000 is that can measure capacitance in the low pF range (though I believe that recent versions of the component tester firmware have improved in this area).
When I started in electronics (more decades ago than I'd like to admit) I would have absolutely loved having something like the component tester.
