Yes you can use the lead-free tips for lead alloys. I'd recommend rinsing them with a lead alloy solder first before actually soldering anything first though (keep applying leaded solder for awhile, to "rinse" off the lead-free alloy that it was tinned with during manufacture). The purpose of this, is to keep from getting some unknown alloy with properties that could cause problems on the first joints you make. Doesn't take long, and is easy to do.
