Author Topic: LED avrerage power  (Read 1368 times)
Offline radelTopic starter
  • Country: in
LED avrerage power
« on: October 20, 2015, 08:14:07 am »
Hi everyone,
I am using LED Vf=3v and If=700mA. This LEDs used some light array project as flashing leds simultanously.
i will turn on 15 LEDs at a time. 5x3 (5rows and 3 coloum) matrix.
Duty cycle is 667ms
ON time=165mS
OFF time=502mS
LES are 2W rated .
please help to find Average power of LED.
Offline tron9000
  • Still an Electronics Lab Tech
    • My Hack-a-day project page
Re: LED avrerage power
« Reply #1 on: October 20, 2015, 08:21:06 am »
your duty cycle isn't 667ms, that's your freqency, from your on & off times your duty cycle is:
165ms / 667ms = 0.25 or 25%
P = IV; so considering you LED is on for 1/4 of the time...your power should be....
(i'm not giving you the answer...I want to know if you can figure it out, least then I know what level your at)
Partsbox.io - orangise your parts!
"If you're green you can only ripen. If you're ripe you can only rot!"
Offline alsetalokin4017
« Reply #2 on: October 20, 2015, 02:47:31 pm »
Since we are being pedantic....
667 ms isn't a frequency, it's a period. The units of frequency aren't seconds, they are cycles per second, ie Hz. Frequency is 1/period (and period = 1/frequency) so the frequency is.....
(left as an exercise for the reader...)
Offline tron9000
« Reply #3 on: October 20, 2015, 03:11:02 pm »
true yes, incorrect terminology on my part, apologies (In my head I see period and get frequency), but something that the OP could figure out.
Hardly being pedantic - there's a difference between knowing the answer and being shown how to get the answer. One's transferable knowledge, the others just reciting.
