as your tracking it with a camera, you should be able to work out how much light you need,
if you need accurate positioning use waterclear leds, noting that they will appear dimmer at an angle but will be a very tight point light source,
if you need crude positioning, look for wide diffused led's
as for a specific make and model, i cannot say, i have never done any active tracking, only long shutters on a fixed area,
