Hi, I'm pretty new to all this, but thanks to Dave I have decided to take the plunge.
I have decided that for my first project I want to create a LED Display, and I have been looking at ICs that should support this.
I have found the ST Micro STAP16DPS05XTTR Driver, and it's got 24 constant current output channels, and I'm a little confused as to whether this can drive the anodes, cathodes or both. In my understanding it should only be able to drive the anodes (being outputs), having output channels, with the cathodes, being driven by a separate shift register, but the typical application circuit show the cathode connected to the pins, with the anode connected to the V+ rail.
Am I getting totally confused here, or is my understanding right, this IC will drive the anodes, and I will need a separate IC for the cathodes, and would the 74HC595 be ok for that? I have linked the datasheet bellow.
Sorry, if that's a little confusing, feel free to ask for clarification.
Daniel
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/DM00084263.pdf
