Hi all,
I have made a PC serial to CMOS level circuit (if this kind of circuit all called this!) using MAX232. It works fine, but I want to add 2 LEDs so I can see data going out or coming in to the chip. I want this to the CMOS level side of chip (T2IN and R2OUT pins).
Can I just hook up to LED's to this pins and ground? If not, what should I do? I looked in datasheet but didn't find anything on this regard.
