Hey Folks,
I just want to confirm something. I bought an LED ring lamp that hooks up to a laptop USB, took it apart and here's a photo of the switch and part of the ring. The LED's are all hooked up in parallel obviously.
So I see they used 3 SMD resistors all labeled "330" which is 33 ohm, also placed in parallel. Total resistance of this combination is: 1/33 + 1/33 + 1/33 = 3/33 = 1/11. ..... 11 ohm.
Some dumb questions:
1. Why use 3 resistors instead of 1?
- does it improve "accuracy" or tolerance, or worsen it?
- is this a safety issue?
2. What is the characteristic voltage-amp curve on these unknown white LEDs?
- If I want to drive them using 3 AAA batteries (4.5 V?)
- If I want to drive them using 2 AAA batteries (3.0 V?) - if even possible
- What resistor would you recommend, or do I even have to change anything?
On another note, I have a whole bunch of LED's bought in China by a friend who brought them back. No spec sheets or anything. How do I go about figuring out the right resistors based on various input voltages (battery multiples like 3, 4.5, 6V) and also 3.3V and 5V (for use with a micro-controller).
How would you recommend I start testing them so I don't burn them out?
For example, if I hook up an amp-meter or volt-meter, what do I look for?
Thanks!
