Hi
Yes sorry that isn't everything. Here's everything, I have tried to put in some kind of flag to have the buzzer only buzz once and LED to remain on.
Analog input, analog output, serial output
Reads an analog input pin, maps the result to a range from 0 to 255
and uses the result to set the pulsewidth modulation (PWM) of an output pin.
Also prints the results to the serial monitor.
The circuit:
* potentiometer connected to analog pin 0.
Center pin of the potentiometer goes to the analog pin.
side pins of the potentiometer go to +5V and ground
* LED connected from digital pin 9 to ground
created 29 Dec. 2008
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
// These constants won't change. They're used to give names
// to the pins used:
const int analogInPinR = A0; // Analog input pin that the potentiometer is attached to
const int analogInPinG = A1; // Analog input pin that the potentiometer is attached to
const int analogInPinB = A2; // Analog input pin that the potentiometer is attached to
int sensorValueR = 0; // value read from the pot
int sensorValueG = 0; // value read from the pot
int sensorValueB = 0; // value read from the pot
int outputValueR = 0; // value output to the PWM (analog out)
int outputValueG = 0; // value output to the PWM (analog out)
int outputValueB = 0; // value output to the PWM (analog out)
int outputR = 10;
int outputG = 11;
int outputB = 12;
int flagR = 1;
int countR = 0;
int toneR = 0;
void setup() {
// initialize serial communications at 9600 bps:
Serial.begin(9600);
pinMode(outputR, OUTPUT);
pinMode(outputG, OUTPUT);
pinMode(outputB, OUTPUT);
void loop() {
// read the analog in value:
sensorValueR = analogRead(analogInPinR);
sensorValueG = analogRead(analogInPinG);
sensorValueB = analogRead(analogInPinB);
// map it to the range of the analog out:
outputValueR = map(sensorValueR, 0, 1023, 0, 255);
outputValueG = map(sensorValueG, 0, 1023, 0, 255);
outputValueB = map(sensorValueB, 0, 1023, 0, 255);
if (outputValueR == 0 && flagR == 1) { //if red is pressed and tone red gone flag is up
digitalWrite(outputR, HIGH); //trun on read
flagR = 0; // reset flag R to off
toneR = 1; // set tone falg on
else{
digitalWrite(outputR, LOW);
if(toneR ==1){ // make a tone for a set amount of time
//Red tone 1
// play a note on pin 6 for 200 ms:
if(countR <= 1000){ //if Red counter is below 1000
tone(6, 220); // play tone
else{ // else if red counter is above 1000
noTone(6); //stop tone
countR = 0; // and reset the Red counter to off
countR++; // increment read counter
if (outputValueG == 0) {
digitalWrite(outputG, HIGH);
else {
digitalWrite(outputG, LOW);
if (outputValueB == 0) {
digitalWrite(outputB, HIGH);
else {
digitalWrite(outputB, LOW);
// change the analog out value:
// analogWrite(analogOutPin, outputValue);
// print the results to the serial monitor:
Serial.print("sensorR = " );
Serial.print(sensorValueR);
Serial.print("\t outputR = ");
Serial.print(outputValueR);
Serial.print("\t sensorG = " );
Serial.print(sensorValueG);
Serial.print("\t outputG = ");
Serial.print(outputValueG);
Serial.print("\t sensorB = " );
Serial.print(sensorValueB);
Serial.print("\t outputB = ");
Serial.println(outputValueB);
Although it compiled ok, it still either doesn't stop the buzzer or it doesn't work at all along with the LED.
Many Thanks for you help
