I've got a cheap ebay LED watch. It has enough empty space inside for a moderately sized lipo battery. It was originally powered by a CR2016 lithium cell, which ran low pretty quick, and I put a CR2032 inside instead. I'd like to make the inner watch module rechargeable once it goes dead, rather than replacing the battery.
Bu this leaves me with an issue: Voltage. The original cell was max 3.0v, and the cell I want to put in will be up to 4.2v
What regulator would be the best to use in a case like this? The watch is only on when I press the button, its otherwise sleeping. I chose red LEDs since they lit at a lower voltage than blue.
Long story short, I need a linear regulator that can drive the 3V watch from a 4.2V lithium cell. I've never shopped around for low power linear regulators before, figured I'd get some input first.
Thanks!
