Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
led's using a 12 v supply
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: led's using a 12 v supply (Read 1264 times)
spike47
Contributor
Country:
on:
October 18, 2015, 03:50:26 pm »
how do I work out what resister to use to be able to light 14 led's , using my PC's power supply of 12 volts .
cheers
spike
Logged
jeroen79
Frequent Contributor
Re: led's using a 12 v supply
Reply #1 on:
October 18, 2015, 04:18:08 pm »
Determine the LEDs forward voltage and current required for the desired brightness.
Calculate how often that voltage goes in 12V.
That is how many you can put in series.
The remaining voltage goes over the resistor.
Use Ohm's law to calculate the value of the resistor from a knowm voltage and current.
Or use:
http://led.linear1.org/led.wiz
Logged
German_EE
Super Contributor
Country:
Reply #2 on:
October 18, 2015, 06:35:38 pm »
(Supply Voltage - (Voltage drop of LED x Number of LEDs))
LED Current in Amps
14 LEDs in series will be a problem because even at a 2V forward voltage drop that will need a 28V supply.
Logged
Warren Buffett
mariush
Super Contributor
Country:
Reply #3 on:
October 18, 2015, 06:55:55 pm »
You can split your 14 leds into smaller segments and use one resistor with each segment.
Last Edit: October 18, 2015, 07:00:25 pm by mariush
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
