Hello chaps this is my first post so please be kind.
My nippers TV is blowing the power supply board 5Amp fuse, I am not an electronics engineer but i do have a basic knowledge of components very basic to be said.
I have found that the bridge rectifier is buggered this is a given, I have also tested the other diodes on the board and they all check out fine, and none of the caps are blown or swelling pointing to them. but on the hot side of the board there is one another diode that reads 0.124V in both directions.
Is this buggered I have never had a reading like this before from a diode in circuit and I don't know if another component could cause this (WTF) reading without removing the diode which I don't really want to do at the moment because really what the hell is this.
I only have a multimeter and I know you have to remove caps out of circuit to test them, hopefully that's correct.
Can you give me a pointer nothing is burnt on the board i have tested all the underside SMD resistors and alike. Like I said I am a noob but not totally thick just stumped and confused.
The bridge rectifier is on order X10 from Ebay and I have not got them yet but the other diode has thrown me a curve ball do I need to purchase this one as well. problem is I don't have the schematics for the borad and i am shooting in the dark and determined to sort it out, like dog with a bone, lol.
Many thanks upfront really appreciate your advice and time.
Take care chaps
Simon
