100mA/h seems wierd unit (as stated above, Ive also seen W/h written, but that's the internet...) current change of 100mA in an hour.
With 100mA constant current you are draining 100mAh in one hour.
So just convert the dischargetime to hours decimal and multiply with the constant current used to drain.
5 7/60 h * 100 mA = 511.6666... ~ 512mAh at 100mA load.
That's rather poor for 18650 so I assume you got either old laptopcell or old laptopcell rebranded as new chinese cell.
Not even two watthours at nominal 3.7V figure so even alkaline AA has more energy than that.
