I've been trying to solve the following problem: How do I create a high constant current source at very low voltages, using a buck converter? When I say low voltage I mean between 0.5V to 2V, and when I say high current I mean the lowest useful output is 20A, and it can get up to 200A.
The reason I need this setup (skip this paragraph if you don't care) is to power large, "short" coils to create very powerful magnetic fields. This has to be kept up for at least 5 seconds, but probably no longer than 30 seconds (so a capacitor-discharge setup won't help). It's designed to test the reaction of various chemicals to magnetic fields, as well as separate ferromagnetic materials (like magnetite) suspended in fluids. These coils sometimes have a resistance of less than 0.02 ohms.
Right now the power supply that's powering these is a massive, silicon-iron toroidal transformer. It hooks up to the mains and has a massively thick secondary winding (3 or 4 turns of it) that feeds into a brick-sided rectifier. It can deliver a constant current of between 200A and 800A, and looks like something victor frankenstein would use. It's moved around on a cart and weighs maybe 30kg.
I realize that there's a practical physical limit to what you can get out of a switchmode converter, due to the thickness of the conductors. However, currents as "low" as 20 amps are useful as well, especially if such a power supply can be made somewhat portable (so they can be moved around the lab more easily).
Here's an example of a buck converter that I've been working with:
http://www.ti.com/product/TPS40057It can indeed output 20A if it's cooled properly, and deliver voltages as low as around 0.75V, but what I'm missing is the constant-current component. If I feed the output of that circuit through a 0.02-ohm coil, the voltage isn't low enough and the current-limit is tripped, turning off the controller. What I've been doing for testing purposes is the simplest thing possible -- I place a length of nichrome wire in series to limit the current (so much of the power is wasted on heating that wire).
There are all sorts of extremely high-current buck converters (like the TPS40090 monster) that can deliver voltages as low as 0.5V, but all of the ones I've seen only have a current-trip limit, not a constant-current function.
Is there a way to "add" constant-current functionality to an existing buck converter? (I realize that that's a pretty broad question...)
The circuit (device) doesn't have to be too small or light, and its efficiency doesn't have to be extremely high (though ~75% would be nice). Should I pump the output of a non-constant-current buck converter through a very low-voltage constant-current circuit (thereby burning a lot of it as heat)? Is there a better way anyone can think of?
Sorry for the extremely long post. Any ideas would be helpful, thanks.
