I think electrolytic capacitor life is always a concern. At 4W, however, it doesn't seem like the unit will make significant heat...which is an electrolytic cap's biggest enemy.
If you are really concerned, you can check out what manufacturer/series of caps they used when the unit arrives. Or check online to see if anyone has pictures.
You can use the rule of thumb that a capacitor's life doubles for each 10 degrees Celsius it is operated below it's rated temperature. That is, if you operate a cap rated for 1000hr @ 105*C cap at 85*C, then its expected life is 4000 hours. If they use garbage capacitors, then maybe take the manufacturer's specs with a grain of salt.
If you are really in love with a certain power supply from a design/usability standpoint but it uses crap caps, then you can always swap out the caps preemptively. (Though, I'd be wary of the quality of the other components too.)
