Hi, newbie here with a power supply regulator question. I've built this regulator from Art of Electronics 3rd ed, around page 608 depending on your copy. It is supposed to dual-track from 0V to 25V.
For most of the range it works very well. The + side seems to work full range. However, the tracking at low output voltages doesn't work on the negative side.
I observed that when the potentiometer is set to 0 ohms, pin 3 (+ input) of op amp A1 is -1.24V as expected. However, since the negative supply for the op amp is also -1.24V, and since this isn't a RRIO device it won't output -1.24V. Instead it outputs around +0.3V. Op amp A2 is an inverter and ideally would set the adj voltage on the second regulator to 1.24V causing it to also output 0V. But instead the max output voltage of A2 is -0.3V + Vdropout. I modeled the positive section in TINA with approximately the same result.
Link to OPA27 datasheet
http://www.ti.com/lit/gpn/opa27I feel like the negative supply for A1 should be -5V on the bottom rail and 36V on the top similar to how A2 is powered by +5 on the top rail and -36V on the bottom.
What am I missing?
