hello, can anyone recommend any cheap little circuits that can be setup to trigger at set voltages.
for example. when i sees X voltage it will trigger a relay or transistor. and the unit can be adjusted with a pot. to X voltage.
even better is there is such a unit that does high and low settings. max and min.
(VSR voltage sensitive relays are on the market but cost over $50) retail stuff to $
thanks
