Author Topic: Linux electronics circuit simulators  (Read 3883 times)
pereczes
  • Guest
« on: April 27, 2014, 01:18:21 am »
even with the risk that somebody will hate me for the tens of posts I am starting, but this is my speed, please give me a cold shower ;)
Had a look at Oregano, but documentation is poor. Got lost on forums.
Let's take a simple example: I have this LM393 and I want to implement a delay timer with it. Is it possible to simulate at least such a trivial circuit with any of this software?
Offline TerminalJack505
Re: Linux electronics circuit simulators
« Reply #1 on: April 27, 2014, 01:59:45 am »
The only Linux simulator that I have used is Qucs.  It had a lot of potential but it seems like the developers abandoned the project.
It's usable so you might give it a shot.  A lot of the circuits I tried to simulate wouldn't.  At least not without having to jack around with a bunch of parameters.
Offline c4757p
  • adieu
« Reply #2 on: April 27, 2014, 02:07:09 am »
Screw all the native Linux sims, run SPICE in WINE. Works a treat :-+
Edit - er... LTspice. Not just any SPICE.
« Last Edit: April 27, 2014, 04:44:59 pm by c4757p »
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: April 27, 2014, 05:09:38 am »
Sounds like normal SPICE to me  ::)
Guessing Qucs is based on... 3f5, or XSpice?  Which is the same basis for most any other flavor you'll cross today, give or take their own proprietary mods/extensions.
Seven Transistor Labs, LLC
Online bingo600
« Reply #4 on: April 27, 2014, 02:19:13 pm »
I use lts-pice in Wine on a linux mint 14 , works excellent
/Bingo
Offline Franz Zinn
« Reply #5 on: April 27, 2014, 04:19:45 pm »
If you are comfortable with the spice syntax try ngspice http://ngspice.sourceforge.net/
Offline mrflibble
« Reply #6 on: April 27, 2014, 04:33:49 pm »
ltspice running in wine. :-+ Nuf said.
Offline richard.cs
  • Electronics engineer from Southampton, UK.
    • Random stuff I've built (mostly non-electronic and fairly dated).
« Reply #7 on: April 28, 2014, 08:36:49 am »
Another vote for this.
Offline Dago
    • Electronics blog about whatever I happen to build!
« Reply #8 on: April 28, 2014, 10:28:12 am »
This works great for me as well!
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
