You may want to read https://www.eevblog.com/forum/projects/lithium-ion-charging/msg624770/#msg624770
Also read the rest of his posts in https://www.eevblog.com/forum/projects/diagnosing-lithium-cells/ , it's someone who researches lion cells.
I don't see anyone using 18650s to run a 700 size heli on 150 Amps.
18650’s are commonly used for electronic cigarettes. For this, they’re commonly used in single and dual (parallel, occasionally series connected) configurations. In the simple mechanical mods, the batteries are hooked directly to the coils (a 0.1 to 5 Ohm Load) through a switch; in the more advanced configurations they power a buck/boost converter, which is capable of delivering up to 200W for 5 to 10 seconds at a time.
That’s a lot of power out of what you call a low current cell. (In fact, I’ve got some IMR18650 cells here rated for 30A continues output.)
Laptop battery packs also traditionally used 18650 cells and were capable of putting out tens of amps, and that was 20 years ago!
Tesla battery packs are made out of 18650 cells and can be fast charged.
By the way, the aforementioned IMR18650 cells are pretty cool. These don’t have built in protection circuits as they’re Lithium Manganese. This chemistry means the batteries don’t violently explode if damaged or overheated; instead they heat up a bit, maybe put out some smoke and then slowly break down. There’s also the newer INR cells, which are Lithium Manganese Nickel. These have the thermal stability of IMR cells, but can put out over 50A!
In fact, the only real advantage Lithium Polymer cells have is that they can be custom manufactured in a specific size and shape, allowing you to pack more capacity into a given area then you could with 18650 cells. (Which is why high end laptops now use internal LiPo packs, instead of external packs filled with 18650s.)
The other advantage LiPo has is in the number of discharge/recharge cycles (500 to 1000 for high end cells). Though, modern Lithium Ion chemistries are catching up—if not surpassing—LiPo in that area.
So no, 18650 cells aren’t relegated to low current usage.
