1. Have to make a led level indicator of lithium battery of 7.4V (two cells in series of 3.7V each).
Led level indications are 0-20,40,60,80 & 100% i.e by 5 leds.
2. Need to make it simple by voltage measurement only. Voltage range of battery pack is 5.7V to 8.4V. Need to break that into 5 different voltage ranges & then indicate by led.
3. I know voltage measurement is not accurate way, but in most application its good enough & I ave to keep simple in this application.
4. Currently doing it by MSP430G2553 MCU & its working fine, but I was thinking is there any dedicated IC available for this, need to be real low power?
Problem with MCU is everytime I have to burn program in it.
Check lots of chinese power banks, they have some dedicated IC, but there parts number are not traceable or available on net.
Any low power ic solution for this?
