Hi All,
Has anyone order this kit and tried to build this FM transmitter? The kit I received has parts that are not longer supplied with the original diagram. One of these is the varactor which is replaced by a PN2222 transistor with one of it's legs cut off. The second is an MV209 which is a tunable inductor and now the kit supplies a core with wires which you have to manually wrap around with 7 turns.
I started to put this together on a breadboard instead of the supplied pcb to see if it will work or not. However I'm not getting any luck. Just asking to see if others on here have played with this kit.
